- 2,102
- 32
- 38
- Delta Junction, Alaska
As for locating a "leaking" accessory, I have used a volt meter between the live feed & the frame. Be sure you have good connection (bare metal) when testing each appliance, or you might miss the problen. Your only talking about a couple of volts. I had one on an M211 once - it was the starter contacts - just gummy and dirty.
Comercial battery disconect switches are availiable, with adequate capacity ratings. Because of an engine coolant heater (M35A2), my batteries are under the passenger seat. I located the disconect switch on the battery ground, in the coolant heater compartment ( which used to be the battery compartment on most trucks). Locating the switch on the ground cable, simplified things, in an area that had more room.
Lee in Alaska
Lee in Alaska
