rfischba1
- 1
- 16
- Fort Meade MD
Anyone have any advise on what might cause a battery post to melt down on a duce 24 volt system. Maybe a short in the battery cables? Batteries are almost new.
A ruined battery post is not uncommon, I have melted my fair share over the years. They can be repaired, though. Get a replacement post from NAPA, drill, tap, install replacement and continue to use your battery.
The best result, I would imagine, since I haven't done this, is to use a mold and pour a new terminal per instructions in TM 9-6140-200-14 (image below).
I don't think "grease" would make a good electrical connection. Noalox or Penetrox, OK.I would screw that new studded post in with nolox or oxguard on the threads. At least some grease...
The threads pull the contact together, the new post against the finished flat old surface. The threads don't have to carry any current for it to work.I don't think "grease" would make a good electrical connection. Noalox or Penetrox, OK.
I have also been assigned to motorpools that poured new terminals on batteries.
