battery question
stump
Henderson nc
Clean the post on battery 2 and check the wire from the pasenger side alternator to the battery clamp on the battery closest to the firewall with the cable off the battery using a ohm meter.
Warthog
245
OKC, OK
yes, i got 12v won the driverside and 24v on the passengerside. i swaped the gen 1 bulb with the gen 2 and i still dont have a gen 2 light. i alsow swaped the gen 2 relay with the volt gauge relay. still nothing. gen 2 test good off the truck. im about ready to pay som one to fix it for me.......... this is starting to stess me out( that why i worked on the rear diff today).
Okay, you say you have 12v and 24v. On which of the two wires? Red or Brown? If Red then the battery feed wiring is okay. If also brown "WITH THE KEY ON" then the interior wiring, including the diode, bulb and relay are also good.
Please give us more detail if you want help. Pictures would help also.
Are you sure the GEN2 is wired properly? Has the wiring been hacked on at all?
johnsr
lafayette in
i get 12v on the driverside on red and on brown with key on. i get 24v on the passengerside on red and on brown with key on. if i use a volt metter going from batt to alt i get 24v and if i go from alt to batt i get 24v. but if i dirve the truck all day, the front batt (12v) alwas has a full charge. the back batt (24v) is around 50% charged. volt metter in the cab is on the very low end of green almost yellow. i have 2 new batteries in the truck. this is why i hate idiot lights, give me a gauge any day.
Warthog
245
OKC, OK
Okay so it looks like the interior wiring is okay, the alternators check out and the batteries are new.
Check the two large red wires on GEN2.
Wire 2A is attached to the ground terminal and goes to the 12v Positive terminal block next to the Brake Master Cylinder. Check to see if the blue fusable link is blown.
Wire 2C is attached to the Positive terminal and goes to the 24v Positive terminal Block behind the rear battery. Check to see if the blue fusable link is blown.
Also double check the 2 prong connector on GEN2. Clean it with some Electrical Contact Cleaner and use a cardboard nail file if needed. I have seen many connectors that are extremely dirty/corroded. You many need to replace it. The ones at the parts store use red and wite wires.
johnsr
lafayette in
ok Warthog you just said the evil f-word (fusable link). i have never had a pre90's chevy that i did not have a fusable link blow on me, mostly the main power wires. i will check those in the daylight.
so this brings me to a thought i had when i first got the truck. cut out the fusable like and replace them with fusses. what do you think? i was looking at painless and found this.
Painless Performance: CirKit Boss®™ Auxiliary Fuse Block/7 Circuits/Weatherproof OffRoad
Painless Performance: CirKit Boss®™ Auxiliary Fuse Block/3 Circuits/Weatherproof OffRoad
johnsr
lafayette in
just replased the fusable link up by the master cylinder, it was blown. the insulation was still good but fellapart when i touched it. gen 2 light comes on and i am charging.
thank you for all the help.
