- 413
- 68
- 28
- Brookings, SD
I did a bad thing and left the master on after doing some electrical diagnosis on my M923. I think it's a PITA having those batteries under the seat in my M923 when it comes to working on them. Here are shots of the box all rusty 'n such. Nice of Minot to install a new box and wood before they sold it. Plus, I wanted to put a VIC, surge protector, battery minder, etc. under the seat anyway so I'm relocating the batteries.
Here's the battery minder I'm putting under the seat doing a "bench" test. A steal for $50 off ePay - google "Genius Gen4". A true four bank minder.
So I went down to my FLAPS and picked up a Battery Relocation Accessory Kit. I'm ok with losing the small tool box - it doesn't hold all that much BII anyway. Here are shots of the tool box and relocation box side-by-side and inside the new battery box. The Kit has EVERYTHING. All new battery cables, boxes, holddowns, bussbars, and every fastener to do the job.
Here are shots of the old short braces and new ones, and old and new side braces. It's designed to hold the weight.
Here is the area stripped out and repainted ready for new parts. The directions state you need to take both tanks out but you really only need to take the bottom one out. OH, and those long bolts that are on the tanks straps are 6-1/2" - kind of tough to find. The directions say to reuse them but I had to cut them off - John Deere has them.
The directions are ok to follow. I would not have been able to figure out the correct fasteners without them.
I can post the instruction in hi-res pdf if there is a need.
As soon as the shop temperature is back above 15 degrees, I'll post pics of the install of the box and how it turns out. Definitely by this weekend.
Al
'84 M923
Al
'84 M923
