Battery Size needed for Frankencab M923
Nogueremuseum
Pensacola, FL
Hi Guys, I need to swap out the four sealed, fairly small, Hawker 12 volt starting batteries on my 1990 BMY M923A2 ROPS Frankencab. These are mounted in two removeable battery boxes in an outside compartment on the passenger side of the truck. They are an unusual size, slightly lower than normal, that is not quite compatible with regular 4Ds or 8Ds. When I checked with Hawker a couple of years ago, they wanted about $2500 for a new set of four batteries. Hopefully, someone has already figured out what oddball sized battery can fit in these boxes. Cheers!
Nogueremuseum
Pensacola, FL
I replaced all four of mine with conventional batteries. If I can remember, I'll get some pics of them tomorrow.
I'd appreciate it Russ. Did you use 4 car sized, or two large ones? I'd like to keep them in the regular battery boxes. If they get pulled out, there is more room. Cheers!
Nogueremuseum
Pensacola, FL
I finally went with four 6TL wet cell batteries from O’Reilly Auto Parts. They have 750 CCA each, and weigh 73 lbs. apiece. Price was $203 each, then a 10% military discount. The two 6T AGM batteries I found were $499 and $799 each. The 6TLs were an absolute perfect fit in the original battery boxes. Cheers, and thanks for the inputs!
