Battery Switch on or off when driving?
nitrox2595
Hampstead, NC
I searched and searched. I am sorry, I have been working 18 hour days since hurricane sandy. My question is, When you are driving the M923(We converted to 2 -12Volt batteries), do you need to keep the battery switch on while driving? I noticed that, after the truck is started and I leave the batt switch on, I hear a belt squeal for a few minutes, and then it goes away. When the truck is running, and i leave the switch off, the generator/voltage guage shows activity, and does the opposite when switch is left on. What's the proper way? All and all, the truck runs fine, except for an air leak that drains the system in 15-30 minutes.
jwaller
19
Columbia, SC
yes you must leave both switches on or you may damage the brain box. just tighten the belt. it's trying to charge the batteries.
Tlauden
Halifax Pennsylvania
Sounds like you need some new belts....
It wouldn't make sense to turn the battery switch off, while I have never driven one of these trucks I would think the concept behind a battery switch on all vehicles is the same. Honestly it sounds like you have some electrical issues that need tracked down
juanprado
2,760
Metairie/La (N'awlins)
I thought it needs to be on to power everything. At least that is what I remember reading. Power up, start and the shut down sequence is the reverse. lights off, Shut down, and then power off. I remember seeing something about the ABS being real sensitive to voltage if the proper sequence is not followed you can blow the fuses, ecm, or solenoids.
I did not realize it would even run with the power off.
73m819
314
gainesville, ga.
Try READING the -10, there is a lot of info you need to know in it and you will not be asking questions like this.
nitrox2595
Hampstead, NC
Thank You for the answer. I apologize for offending people who had to take 15 seconds out of their, obviously busy schedules, telling me to read something i have no idea about. I appreciate your response.
212sparky
Monroe/ Ohio
The -10 -20 -34 are all tech manuals. -10 is operator manual. It is a good nightly read.
