Battery Tender
MAXM37
Newmanstown, PA
Good, so would I switch to the other battery every other day or will the tender charge both if they are connected?
Thanks Guys for the info, sucks when you can't start the darn thing when you need it in the cold winter months!
i use a 250 amp boost charger that sure helps get one on sale for under 200$ that and a 1500 watt circulating heater and no more problems my brother has a solar tricle charger he says that helps he lives in thompson manitoba so there used to cold
emr
24
landing , new jersey
read the other post here, and i explain what u want to know there...batteryhookup by 4 bogginschevy is the post it is spelled out for u using multiple 12 volt tenders also...
