Battery terminal meltdown
Steamynachos
Calgary Alberta
Today I went out to the truck and went to start it and all i got was a quick turn then nothing no power so I checked the batteries and the positive post on one batt. has melted down the middle and there is only half a post left and the terminal wont go small enough to fit. These are the walmart energizer batts. and are only 6 months old is there any way of fixing the post? or will walmart take the batt in exchange.
Westech
CPL
6,104
207
cow farts, Wisconsin
well try to swap them out, but if you cant a batteries + may be able to rebuild the post. You can do it too with lots of solder and some tin foil (i have seen it done). If you do get them fixed/replaced make sure to clean the cables and the ends. Thats why they melt down, there not 100% clean and they arc when you hit the started and the arc just melts the lead posts.
cranetruck
75
Meadows of Dan, Virginia
A good connection should have less than 0.001 Ohm resistance. A high terminal resistance will produce a voltage drop across it and generate enough heat to melt the post when 300 amps flows through it....
reuben
Spencer TN
commen problem, I developed a couple missing posts on the dozer before i learned the importance of keeping the terminals clean and tight. 24V is welding voltage and a slight gap caused by poor connection will cause a welding arc to start. might be able to rebuild it with a good hot soldering iron and extra lead, or if the battery is gonna stay in it, could melt the terminal and clamp together for a really good connection. or pull the clamp off the wire and solder the wire onto the top of the post. might need a propane torch to get enough heat to do it, and some acid core solder. and cut the wire back to get clean copper so it'll take solder better.
randyscycle
Rhoadesville VA (where!)
Re: RE: Battery terminal meltdown
reuben said:
or pull the clamp off the wire and solder the wire onto the top of the post. might need a propane torch to get enough heat to do it, and some acid core solder. .
Absolutely DO NOT use a torch anywhere near a battery!!! Charging batteries generate hydrogen gas. Think Hindenburg........Also you should never use acid core solder for anything electrical.
mangus580
282
Western NY
RE: Re: RE: Battery terminal meltdown
Its actually really simple... Here is how I did mine.
I set the battery on a mill, cleaned the old post off flat
Drilled a hole in the center, and tapped it for one of those side to top post converters.
Thread that in, nice and tight, and voila! you have a new post.
I think I have had one like that on my deuce for going on 2-3 years now.
cbvet
20
Northwest (Knox) Indiana
Saw this problem on a truck in 'Nam.
Official Seabee fix was using a mold that wrapped around the bad post, then filling it in with melted lead. Worked fine.
I like Mangus's idea though. You ought to be able to cut the damaged post off with a hacksaw, file or sand it nice & flat, & tap it for the top post converter as he suggested.
Eric
CBVET
mangus580
282
Western NY
Yanno Eric, now that I think about it, I think thats how we ended up cutting it off. We just drilled it on the mill.
desertfox
Aztec, NM 87410
Replacing the post is probably the best and most simple. The cause is most likely a dead short in your system. I had this happen on a truck recovery when attempting to change the battery pack. When I touched the positive cable to the battery, instant melt down. Ran the truck home with out electrics. 250 mi. Found out the wiring harness had rubbed a hole in a wire against the frame just below the air cleaner. It had toasted both batteries and the generator.
CGarbee
523
Raleigh, NC
I've cut off the offending post and drilled and tapped (just used a screw, never thought of using one of those adapters like Mangus used--good idea), and I've done the mold and pour in new lead route (helps having a burner and pouring pot from wiping cast iron pipe laying around in the shop), but in the last couple of years, I've gone to using batteries with threaded posts.
The nuts holding a battery cable on the threaded post seem to stay much tighter than the ones on the battery clamps, and it's less stuff to have to worry with when changing out batteries...
Good luck with repairing/exchanging yours.
