Battery Voltage cycling after startup 1st green - yellow, then max - green, the max'd
TOBASH
3,961
Brooklyn, NY
Sorry, I don’t see this holding, I’ve seen mounting tabs break from regular usage.
especially if the rear block support is not added, that’s why it was added to the exhaust stud.
The problem is going to be when it gives on the freeway, it’s going to be quite a mess under the hood.
If RWH says that, I gotta believe him.
You have a 60 Amp, which is common.
There are a few for sale on FleaPay and I'm sure the vendors here have dozens.
You should consider buying one of those if RWH says your repair is suspect.
Best,
T
