- 1,404
- 1,091
- 113
- State College, PA
Having read a few threads on battery related problems, here is a little tutorial on preventing them.
Starting (and glow plug) systems require a considerable amount of current from the electrical system. All components of the system need to have clean and reliable connections from the battery post to the final connection. Any imperfection can cause the system to not function properly or intermittantly. Minor corrosion between mating conections will have a minimal impact with low current demands. With high current systems, as the current demands increase, the slightest imperfections will result in system failure and possible damage.
Here is what I recently did to the M1009 to help prevent any battery related failures.
Remove all the battery cables from the batteries.
Cover the tops of the batteries with a rag to prevent accidental shorting of the terminals and keep any acid from getting on your skin.
Remove the cover to the positive bus bar.
Remove all the nuts on the terminals that the wires connect to.
Remove the bus bar from the plastic holder.
Clean the areas of the bus bar that the terminals attach to. It is not necessary to clean between the attachment points or the back side of the bus bar.
I used a Scotch Bright pad. Excessive and aggressive cleaning will remove the plating from the copper bar.
Clean the front and back of the wire terminals, external tooth washers and nuts. I used a wire brush for this.
(I also coated my terminals with a copper conductive compound used on tower grounding systems.)
Make sure you have clean shiny terminals and bus bar connection areas.
Reattach all terminals to the bus bar and tighten all connections.
Use the external tooth washers for added electrical connection.
Be careful not to distort the terminals while tightening.
Reinstall the protective cover over the positive bus bar.
Now do the same on the negative bus bar.
Battery connections are next.
