gimpyrobb
dumpsterlandingfromorbit!
- 27,791
- 783
- 113
- Cincy Ohio
Jump on egay and get a used hydraulic set. They are way mo better.
They average about $240 if you search "hydraulic bead breaker" even used.. but the money isn't really the issue. Trying to verify what I am searching for (details or specs) to know it will work to breakdown these tires. This for example doesn't appear to be big enough. Whereas this does...Jump on egay and get a used hydraulic set. They are way mo better.
I totally agree with "gimpyrobb" here. Get the hydraulic one. You will regret it if you go with the manual one. I even used my impact wrench on it, though your not suppose to. It was still a pain in the A$$ ! Go with the hydraulic !As someone thats used both, there is no comparison, go hydraulic. I've used one like in the 2nd link. Never seen the one in the 1st.
Lee that must be an Alaska saying I have told it to many young folks in the past too I still use it today when some one tells me I make it look easy.An Old tire man once told me, that if your really working hard, to change a tire, your doing it wrong!.. The bottom line is that a "duck bill" hammer and a slide hammer, are about as fast as anything. That precludes the fact, that you have to learn how to swing that hammer. Sledge hammers don't get it! You need the right tool. I often tend to think that "tire work" is a young mans job. However, I still do mine. I want the valves straight, tubes in straight, no hands full of dirt left in the tire, flap straight and tube not pinched. So I do my tire work in self defense.
Lee in Alaska
Is yours mil-surplus or commercial ?I bought a good hydraulic bead buster and was able with my bad back and knees to bust down 12 tires in two hours. The hardest part was just moving the tires themselves. So save yourself a lot of pain and misery and buy the hydraulic unit.
I bought it from "Northern Tool and Equipment" . I also bought the foot operated hydraulic power supply. The unit itself weighs in at around 30 Ibs so not to bad to lug around. I own all the "duck bill" sledge hammers and "pry bars" to manually break down tires, but after using this hydraulic unit I will never use them again !Is yours mil-surplus or commercial ?
The mil-surplus one I got weighs 60+ pounds .
