ragedracer
- 2
- 18
- Phoenix, AZ
I'm in the middle of replacing the radiator, water pump, etc etc. I had to pull all the belts. I though I knew what I was doing, but something doesn't seem right. I put them back on just like in the TM (see attached pic) but it seems like the driver side alt belt is not aligned correctly. I have the PS pump routed on the first (closest to the block) groove on the crank and water pump pulley, and on the first groove of the PS pump. The Alternator on the outside groove of the PS pump and the center groove of the water pump and crank pulley. But it sure looks like the pulley of the alt would line up better where the PS pump is routed. It's getting dark, so I can't take pics. I don't remember it being like that when I took it apart, but I'm sure it's routed the same way. WTF am I doing wrong??????
Next question: I'm replacing all the vacuum lines to the transmission. I pulled them all off to take them to the parts store to get the right sizes. Now I can't remember which line goes to which on the solenoid part (front of the engine, near the IP). There's 2 lines. 1 from the transmission and 1 from the back of the motor. Does it matter which goes where?
Thanks guys!
Thanks guys!
