Bench seat won't slide
Matt S
37
Los Angeles, CA
I took my daughter and her friend driving today. I slide the seat full forward so she could reach the pedals and now I can't get the passenger side to release. The wire is still attached to the passenger side. I tried moving the mechanism by hand but it won't slide.
I'm not sure how that seat moves. I tried searching the forums but nothing popped out.
TGP (IL)
36
Metro East IL
It's probably bound one side farther than the other.
See what side is ahead of the other, then pull the lever and bump
That side back.
Could also be it's on part of the track that hasn't been used in
A long time and just stuck.
Tom
cucvrus
10,504
Jonestown Pennsylvania
Could also be the cable is disconnected from one side. Easy fix. Seen it many times. The little spring slides over the bend in the cable to secure it to the lever/linkage. Good Luck report back. Once you have it reconnected manually slide both sides back and release the lever. Once back in time in the same notch all should go well. As mentioned. R&R the seat flip it over clean and grease the balls in the track. Live Happily ever after.
Matt S
37
Los Angeles, CA
Thanks you guys! I took the seat out last night. It was not moving on the passenger side. I was able to motivate it with a 3 lb hammer and now it works again. The cable seems ok to move both the releases.
