Best Generator for Veg or WVO
derf
13
LA
The Yanmars on the 016Ds and 016Es and their Chinese copies can run on WVO. I am not sure about longevity, but I know they will run on the stuff.
PsycoBob
11
Auburn, NY
Yanmar & 'Chanmar' 1-cyl air-cooled engines state right in the manual that they use Bosch-compatible injection components. No idea what decade of Bosch engineering, but... Pump is "Bosch type, YANMAR PFE-M type" injector is "Hole Nozzle, YANMAR YDLLA-P type"
Indirect injection engines tend to be more tolerant of WMO & the like than direct-injection engines.
IDI manufacturers include Kubota (John Deere), Izuzu (thermoking refrigeration units), Lombardini/Kohler, Yanmar (mostly older models). Chinese yanmar clone water-cooled engines are often available as DI or IDI, depending on specific model. My Lombardini 2-cyl LDW-602 should run fine on wmo, but I haven't had time to stick a radiator on it yet. :(
derf
13
LA
People have reported getting new "Chinamars" and running them on WVO right out of the box.
PsycoBob
11
Auburn, NY
If I could lay my hands on one of the 4-6hp IDI liquid-cooled engines, I'd use it to run & heat my centrifuge. I got interested right after the EPA cracked down on imports. Pretty nice prices on them, right up until they vanished.
derf
13
LA
I am not familiar with IDI engines. Are they like Listers? You can still get Lister "parts kits" and assemble them yourself.
PsycoBob
11
Auburn, NY
IDI stands for InDirect Injection, like 6.2l engines in CUCV's. DI is Direct Injection, like almost every engine bigger than that.
Small/old designs used a small chamber connected to the main combustion chamber- the injector & glow plug went into the small chamber. The glow plug can heat that space effectively enough to help start the engine. The swirl/turbulence of the air getting forced into that chamber on the compression stroke helped atomize the fuel- important for WMO & other thick fuels. It also allowed injection timing earlier in the stroke with lower-pressure injectors than would otherwise be needed at the same compression ratio. They're less fuel efficient & have more challenges trying to meet modern emission spec than DI engines, as modeling that chamber & the passage leading to it is a PITA. Very small engines also have a big challenge, mostly from the high surface-area/volume ratio in a .3L compared to a 1.6L single-cylinder engine.
I'd imagine one could build one from parts, but it'd be much cheaper & faster to order a palletload delivered to Canada/Mexico & have someone lie like a rug about them. "Scrap steel for traction weight, honest Officer." That'd look amusing in the paper. "OLD junk collector caught importing NEW junk!"
On a related note, the same companies that sold Lister-oid engines now sell air compressors- with a simple plug in the fuel injector port. Add injection parts & proper cams & voila! :beer: Given that many Lister-fans want to run their engines on pure biofuels, I'm not even certain that it's legal for the customs guys to stop them, just too expensive to prove in court that veggie-oil compression-ignition engines aren't covered under EPA "diesel-fueled" regs. There's also been discussion about whether the fed EPA even has the ability to regulate stationary engines, as they aren't crossing state lines while operating.
/Back on topic-
A lister-powered genset can be made pretty bulletproof & fixable with a wrench & a hammer. Downside is the external oiling requirements. Very fuel efficient at ~650rpm, too.
TexAndy
Bee County, Texas
I believe there is a company out there that makes gen sets from LDT-465's
That would most likely be your best bet. Albeit WAY overkill. Who needs 60kW capacity?
derf
13
LA
Good points. I thought IDI was a brand name, not a type. I should have known better since I have a TDI.
