M1165A1
- 859
- 93
- The High Country, CO
Putting in a 24V compressor which will be mounted near the windshield washer tank. Also a storage tank somewhere, location TBD. This will be for airing up after off roading.
Thinking it through I'd like to tap some 24V power within the engine bay. The compressor draws up to 22 - 24 amps at full duty, so I need to find a decent place to tap.
I will probably connect the power through a relay with a switch somewhere on the dash so the compressor won't run full time.
Anyone have a suggestion for the best place to tap into power? And should my power source be tied to the vehicle being on, or full time 24 volt? I can't see needing to run the compressor without the engine or at least vehicle switch on.
