Best Source for CUCV alternators?
rmgill
14
Decatur, Ga
What's the best source for good CUCV alternators? A fella I know is looking for a few sets. East coast or Central plains states is closer to the fellow than west coast.
CARNAC
The Envelope Please.
717
College Station, TX
I have a few that are take offs. Most of these are probably just fine as is but I would rebuild them before use just to be sure. PM me if interested. Need to know how many you want.
jag7720
Kansas City, MO
Will a civi alternator work? I have a diesel van (1987 6.2 Chevy)that I am scrapping and I put on a new alternator about a year ago... can I use this on my M1009?
1,193
If it is an AC Delco 27si, it will fit. You will need to have it modified to work on the rightside alt(isolated ground).
colomil
colorado springs,co
I just went through a parts-store search for the alt on my M1009 and I learned a few things. The case is a large frame 27SI with an insulated ground. That same case & internals were used on several civvy vehicles except they did not have the insulated ground. If you have the phenolic spacers you could probably convert one to insulated ground. I am going to try that today. I will be purchasing a 100A 27SI alternator for a 1984 caddy deville w/ the 4.1 engine. I will pop that back case off and put the insulators behind the ground leg of the rectifier heat sink. I will take photos to show how this is done.
jag7720
Kansas City, MO
I got it at a NAPA store... not sure of the model. It is on the right side of the van. Will it still need modification?
I currently only have on alt on my m1009 and it is on the right side and the truck is 12v only.
If it is a direct swap or small mod I'd like to keep it for a spare.
