blutow
- 501
- 63
- Austin, TX
If you like the blacked out look, paint the studs and lugs flat black and you can touch up at will. If you like the raw silver/galvanized look, they should do fine unpainted. Particularly if you have newish studs that still have most of their zinc. I bought a set of 5 used 24 bolt wheels that were just sitting in the dirt/elements for a long time. Of the 120 unpainted studs, only a handful had any visible rust. A couple of the wheels had some significant surface rust that had to be refinished, but the studs were almost all good.Is it best practice to paint the bolts after replacing? I just put all new hardware and now I’m worried it’ll rust
