Best WMO to gas ratio with FDC bypassed?
Hammer
398
Winlock, WA
Ok, I need to make a trip soon and want to take my truck that has the FDC bypassed, but also want to run WMO to save on fuel costs.
I know the motor will still burn straight WMO if I put it in there, but what would be about the right ratio of WMO to gas to get fairly close to the density of straight #2 diesel?
gimpyrobb
dumpsterlandingfromorbit!
27,787
776
Cincy Ohio
As long as the consistancy is close, thats all I'd worry about. The cooler weather is getting closer, keep that in mind at the end of the trip. I need to start thinning my mix out. I had been running 40 gal wmo and 10 gas.
Hammer
398
Winlock, WA
In my other truck I am running about 40 gallon WMO and a mix of diesel and gas for the rest. Runs great actually.
I should run out there right now while it's still cold and see how it starts (did fine at 30° the other day).
TommyG45
Cleveland Ohio
I third that, I have been runing ~80/20 wmo to gas, and it has been getting cooler. Worse thing I have seen so far is that I had to depress the pedal a bit to get her started, she runs great and loves the 80/20 mix. Before the real cold stuff gets here though, I will go straight diesel. FDC is bpassed.
Tommy
