better late than never
USAFSS-ColdWarrior
Chaplain
6,035
strap a lid on real tight and you might even have some water once you get to your destination.
This is food for thought and creativity....
An M105 Trailer properly sealed for the pool with a second M105 bed flipped upside-down, with hinges, rim seals and hydraulics to raise for sunshade OR NO HINGES, just three or four cylinders to lift the upper bed for a "roof".
Shazam.... One Self-Contained Water Entertainment Unit.:grd:
Biggles
Pawnee, IL
you know you could just get a long piece of flex pipe to stick over the exhaust stack and run into the pool to create warm bubbles.....maybe a little sooty but warm and bubbly none the less. or you could build a manifold that would lay in the bed that you could hook up to the air system for cleaner not so warm bubbles.......just a couple ideas I thought I should share.
