- 12,195
- 329
- 0
- gainesville, ga.
CORRECT, a thimble is NOT designed as a STAND-A-LONE lug nut, the OUTER nut is what gives it strength.The wheel is assembled just as if there are two wheels-just like factory. Just like a typical rear wheel install, the wheel is installed. Then the thimble screws on to stud and is thightened down. Then I install the back up plate-it basically simulates the second wheel. I then use the lug nut to secure the back up plate. The assembly works just as sotck and has no difference in thread engagement.
I didnt like the idea of just having the thible hold the wheel to hub.
Pete
A thimble used first on the studs (unless moded) DOES NOT allow the rim to be flat and tight AGAINST the hub, this WILL allow the rim to FLEX which in turn WILL crack rims AND CRACK/BREAK studs.
The ADAPTOR PLATE or the NEW LUG NUTS would be the safest way to go, no matter how much these COST, it would be CHEAPER then LOOSEING FRONT STUDS going down the road AT ANY SPEED
