BG Products
mkcoen
381
Spring Branch, TX
Anyone use the BG line of products in their vehicles? I was thinking of adding it to my 1009, both the engine and transmission (with a small amount added to the transfer case). You hear a lot of hype about these additives but I haven't talked with anyone that's tried them.
HeadWizard
Chantilly, VA
We use LOTS of BG Products at the shop. Which specifically were you planning on using? The specs on the diesel MOA are good - I use it. The trans fluid conditioner must work, I have it in my 94 6.5 with over 200k. I suppose it would also work in the T-case.
mkcoen
381
Spring Branch, TX
ATC Plus is the transmission conditioner. I suppose if it works on the bands then it probably wouldn't do much for the transfer case.
