Bidders Beware: GL is draining all fluids on trucks
SETOYOTA
451
georgia
I'm the "victim" in this one. the truck had drain pans sitting under it. Worst of all all the drain plugs that were removed were not replaced or stored in the truck. They are missing!
mckeeranger
Eastern Kentucky
I've run into this on smaller items screened at DRMO. Generators and gas powered pumps with no oil, and our M107s had no brake fluid.
"They" also always suck the freon out of refrigeration and air conditioning equipment.
SETOYOTA
451
georgia
Was not indicated in the sell that all fluids drained. found paper work in the glove box where is was road tested in may and signed off on. Everthing is new under the hood, new tires also. Just no fluids. the difs and transfer case are full however, Engine, tranny, and power steering all empty. Good brake pedal. Wish me luck. I need a few drain plugs. Please help.
The batteries are all gone also!
jeep-Jeep
Liberty Hill Texas
I was told by gl that they are suposed to drain and triple wash to remove all fluids .
was not told if they use solvent or water and that could complicate things further.
frodobaggins
Ruston, La
These are base policies. Not everywhere. And I'm sure "some" of them are 'over-interpreted',
but I also imagine some are actually very strict.
Senarmontite
Bremerton, WA
If its any help Barstow, CA does it also, which im presuming all other bases are too from what im hearing. I bought my M36A2 last september and called the site manager to see if i could have someone could check/fill all fluids before i got down there cause im up in WA. But he said no because if theres as much as a small leak on the ground its considered hazardous waste, which a few of you have mentioned already. Anyway my truck had the
fuel, radiator, tranny, oil, and gear oil all drained so i had it towed out.
roscoe
Spencerville, Indiana
Just take them off adjoining truck like others seem to do.:roll:
DUG
Senior Chief/Moderator
74
Mesquite, NV
I drove my truck off of Barstow in April with the fluids FULL. Added a few ounces of DOT5 just for the heck of it. Every truck I have ever previewed at Barstow had fluids in them. Every time I go there I see trucks driven off and trucks driven on to trailers.
emmado22
170
Mid Hudson Valley NY
When I was in, we turned in alot of stuff to DRMO.. The fuel tanks were supposed to be drained, and triple rinsed of all residual fluids, and labeled as such.. Well, we did alot of draining and labeling.. Just not any of the triple rinsing... They never complained as long as it was labeled as triple rinsed. :)
Senarmontite
Bremerton, WA
I guess i chose the unlucky one, i dont know...
But she drove like a champ from Barstow to washington:)
DUG
74
Mesquite, NV
I think it depends a lot on the unit turning them in. Same in the Navy - did things one way on the Connie and another on the Nimitz - even dealing with the same gear.
1,164
EVERY time I go pick up an unknown truck, even if I plan on towbarring it, I take a full 5 gallon pail of GL1 and a pump. You guys gotta' be prepared-you don't know what you are gonna' find.
Clintogf and I picked up a truck at Redstone and PCTrans walked over and introduced himself and warned us that he had found a lot of middle axles here that were low (I was in the process of checking the entire truck over) and sure enough, he was right.
When you go on a recovery, you have to take oil, GL1, wheel bearing grease, the correct coolant, 10-15 gallons of water, etc.
Because honestly, you have no idea what you are going to encounter when you show up.
1,193
Do you mean, buying 40 year old Surplus MVs,site unseen(5 crappy pictures that show few details), is not the same as buying from a used car dealer?
1,164
It's not-it's probably safer rofl
DUG
74
Mesquite, NV
What if you had 8 crappy pics and an expert to look at them?
rofl
