Bigler Boyz Crew Cab M35A2
K10A
Western Co
The truck is very nice (to me) except what you claim about the suspension.
Drive the truck up a loading ramp or through a ditch to flex out the suspension, take pics, then you can say it doesnt bind if that is true. till then..... not so much.
I forsee possibly bent links, ripped off brackets, bent tabs etc.
All I see is driveway poser shots.
Second, there is no binding, no harsh riding, no bent parts ect as a number of members have decided to imply. The traction bars work perfectly as designed on and off the street. For those that don't want to believe it, the offer still stands to come see for yourself in person. I will be more than happy to show you that the bars work.
For the rest of you, thanks for your support.
needmoretrucks
alliance ne.
Do u mean to say there is no slip allowed in his links?:razz
: any spring sprung axle when it is being compressed is going to move towards the shackle side of the spring. In other words the distance of a fixed point on the frame (your link ends) to the axle (where link ends are mounted) is going to increase upon compression (uptravel) of suspension and when suspension droops the axle will move closer to fixed point.
So long story short if you got no slip built into the suspension links you are going to have lots of bind and considering the weight of this vehicle your gonna break something. Probably those light duty link mounts on the frame.
:deadhorse:
