epartsman
- 0
- 0
- Jacksonville/Florida
Unfortunately my 09 doesnt have those stickers however I am going to check the TM for lubricants as if I can use SAE30 here in Florida I may get better performance and lubrication. I change every 3K, a rule that has suited me well as I have had vehicles that if they had no been totalled would have had over 300K miles on the original engine ( was t- boned and rear ended @ 240K and 260K).Does anyone follow the recommendation for engine oil weight listed on the back of the sun visors? It says SAE 30 above 40°F and 10W-30 below 40°F, with either recommended between 40-60°F. I have always run Rotella 15W-40 because everyone else does. I am thinking about changing to the SAE 30 in about a month or so in South Carolina for the long summer. Any comments about better performance or mileage?
To the original poster welcome! Dog head Mods both starter relay and glowplug resistor bypass to the 12V buss bar are a must! Read the TM's and act as if it has a million miles on it and go through everything, all fluids, filters, and repack the front wheel bearings. preventative maintenance is the key. Enjoy!
