Blazer wont start???
44CCKW
Port Republic NJ
I have a 83 CUCV blazer that ran fine a few days ago,Now it wont start??I replaced the batteries as well asthe starter solinoid and all it does is click when you turn the key.It does sound like the glow plugs are cycling but the starter does not turn.Any ideas??
Harold
HAWKMAN
N.E. P.A.
Check all of your connections to be sure that they are all clean and tight, plus check grounds,battery terminals clean? maybe try jumping the soliniod and see if there might be a loose connection there. Hope you can find this info useful
dependable
187
Tisbury, Massachusetts
If you just replaced the solinoid [which would have been my first guess with new batteries and all], it is possible you have a short in the starter motor itself. You could take off starter back plate and look for shorts, burnt or frayed wires or worn brushes, { dirty commutatior.... ypu could try to clean and would only be the problem if you have a oil or fuel leak over it.} if you see any if these, try another starter.
44CCKW
Port Republic NJ
I replaced the starter relay under the dash.Still wont start.What next???
Harold
NEW SO FAR
BATTERIES
STARTER SOLINOID
STARTER RELAY
BATTERY TERMINALS
