Bleeding winch hydraulics?
rhurey
14
Bothell, WA
Put a wet kit and winch on a M923, and after the PTO install things seemed to go pretty well.
But before I fire it up and re-wind the cable on the winch...
I looked in the TM, and can't find out if there's a procedure for bleeding all the air out of the hydraulic lines. Seems to simple to just engage the PTO and go. I missing something?
74M35A2
330
Livonia, MI
Agree with above, no bleeding required. Just engage it and go, as long as fluid level is up. Leave room for expansion.
rhurey
14
Bothell, WA
How was the install? I'm going to be doing one this spring (I'm adverse to that kind of work in snow if I can avoid it).
PTO was a pain. I updated some thread with the exact steps it took to get it aligned. Can be done w/o moving transmission.
Everything else was fairly painless. Since I got a wet kit (from a marine truck) and winch from different sources, I had to acquire the fittings from the valves to the winch, and getting them all installed on the valve was a bit of a Tetris puzzle. lmk if you want the set of parts I ended up with from surplus center to get everything to fit.
