Steelreaper80
- 96
- 28
- Indianapolis IN
Probably stupid questions. When my M925A2 is at temperature, I see blowby coming out of the blowby tube. It is a light grey color. It is not puffing like a steam engine but it is puffing more than I would like to see. I can put my thumb on the tube and hold it and it does pressurize and when I release my thumb it releases the built up pressure. Lately, it is coming out so much from the blowby tube that it drifts up into the engine compartment and I can see it with the hood open and standing at the front driver's side tire. I pulled the oil fill cap and it had blowby coming out of it. I put the cap back on with it not tightened down but just resting on the threads and the blowby did not blow the cap off. Other than having the blowby measured by a repair shop with a computer, how would I know if I have too much blowby? I don't really see blowby from the tube or oil fill when the engine is started and cold. Going down the road even loaded the truck runs cold at about 175 degrees. It only shows up when the temperature is around 200 degrees. Do I have a larger issue of stuck or cracked rings or worn liners or is it normal? Could it just be evaporating moisture from the crankcase when it is close to 212 degrees? It seems to come and go......There is not oil blowing out of the oil fill area. I looked down at the top of the head and everything looked normal other than looking at light grey blowby puffing out of the valve cover.
As far as I can tell the truck is not eating oil. I do have a very slight oil leak somewhere at the front of the engine but I don't think the motor is eating oil.
Second question. When do injectors need to be replaced? The truck has a light grey smoke at idle and heavy smoke after throttling up after idling for more than 10 mins. The exhaust smells strongly of diesel. I don't think that I am getting a good spray pattern and that the injectors are leaking in the cylinder. I could be wrong, which is why I am asking the experts. If I do need to replace injectors.......stock or bigger? I NEED more power. (Damned tamper-proof screw!)
The truck starts very easily and runs great. I just want to get in front of an issue at the shop rather than behind it hundreds of miles from home.
These trucks are older so would running something like Hotshots Stiction Eliminator help?
The truck is ran a LOT and gets regular oil changes at about every 7500-10K miles. I run fuel additives with each tank. Thanks guys, and I tried the search button but it seems less than helpful lately. I get every topic EXCEPT what I am looking for.
