- 4,331
- 1,936
- 113
- Edmond, Oklahoma
Will be doing that first thing Monday.Also, test your small signal wire to the underdash relay for 12volts when the key is in the crank position.
Ordered new ACDelco one today.At this point I would suspect ignition switch.
Suppressor had been removed before truck came to auction.Also, check the bottom most fuse.Also, I'm wondering if the suppressor on the blower motor may have shorted to ground. It can be eliminated.
Not sure about the yellow wire on the schematic showing a 50 with it.
The more I think about your issues, the more I think you have a bad fusible link, wire or connection on a 12v wire feeding the ignition switch and or the heater fan.
Don't bypass a fusible link with wire. Just replace with new. It's a fuse.I have seen the fusible link going to the 12v firewall block partially burn and still show 12v but not carry full load. You can try running a good size wire direct from the battery to that block, that will eliminate a bad link.
