blowing rear main seal
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
So your saying you've done it already?
Is the crank grooved? Might need a "speedy sleeve".
Have you checked the transmission isn't the culprit? Many belch G.O. on the clutch.
DieselBob
13
Arnold Maryland
If it is for a fact engine oil I would suspect like stated above that it has enough wear or a defect in the surface of the crank hub to require a sleeve. Outside chance could be that for some reason the hub has to much radial run out.
DieselBob
13
Arnold Maryland
Something else could be to much longitudinal crankshaft movement due to excessive clearance in the thrust bearings.
gimpyrobb
27,785
748
Cincy Ohio
I'd lean toward the transmission.
Is oil getting on the clutch? That right there is the biggest indicator. Its pretty hard for engine oil to get to the clutch.
gimpyrobb
27,785
748
Cincy Ohio
Take some pics if you have time(and clean enough hands).
I'm guessing you'll drop the trans for this, might want to pull the input shaft cover on the trans and look at the workings in the front of the trans. (pics of that too)
1,172
Where are you getting your seals from? What brand and how old are they?
4 times, how far between?
What do the failed seals look like?
Doug Roberts
Chapel Hill, NC
Input shaft is good, new input housing and mainshaft bearings good. It is leaking engine oil from rear crank seal, not gear oil from the transmission. No excessive end play on crank, crankcase breather is clear and not clogged. There's no excessive pressure from crankcase. Air compressor is not compressing crankcase either. We're getting the seal from White Owl in Kinston NC. Don't know the brand or how old it is.
