Bmp fuel leak
Coltman15
PA
So I walked into my barn and behold a new diesel fuel leak on my bmp. The leak is coming directly out of the pre-heater exhaust port on the bottom of the vehicle. The preheater is off and the valve handle has never been opened to release fuel into it.
I checked every where and I can’t pinpoint a leak from a fuel line. It’s a fairly regular drip, maybe 1.5 to 2 gal in a weeks time.
HELP!
Coltman15
PA
Hmmmm.
Sounds suspicious.
Some photos might help with any analysis and mentorship from those who might have experiences similar to yours.
nopics
Literally not much to take pics of. No actual leak in the interior of the vehicle. Fuel is dripping right out of the exhaust of the preheater, located on the bottom right of the chassis.
I dont know if i bumped the pre-heater switch or smoke generator system and it released fuel. I started it up the vehicle and it seems to have stopped...? Do BMPs have a pressurized fuel system that leaks as the air pressure slowly dissipates when the vehicle sits, then leaks?
Coltman15
PA
So it turns out, the way to stop the leak is to start the vehicle right after you fuel it. No idea why this works...... if you just fill the tank without starting the machine, it will leak.
Coltman15
PA
Well that would explain it... we only fueled it while it was running anytime we put fuel in it... WEIRD! Glad you got it figured out!
Y’all it’s back. The leak is back. Same spot. Do these machines use air to pull it out of the tank? If I shut her down without bleeding of the pressure, does it siphon fuel to the preheater or exhaust smoke generator?
Still coming out the pre heater exhaust hole
USAFSS-ColdWarrior
Chaplain
5,532
I have a diagram of the complete fuel system ,my problem is how to upload it to here ?
UPLOAD INSTRUCTIONS:
In the top bar of the REPLY Box you'll see a "framed picture" Button near the right side. Hover your cursor over it and it will highlight with "Insert Image".
Clicking on that Button will allow you to upload various formats of pics, and PDF files too.
Looking forward to your uploads [thumbzup]
Augdog1964
15
Richmond, IN
I'm guessing that a solenoid may be used to draw fuel to the preheater, and despite the preheater switch not being on, the solenoid is stuck in the "open" position.
We never had ANY leaks from her at all and perhaps the switch was moved and returned to off afterward, but the solenoid stayed open?
