bobbed a deuce, original bed
goldneagle
1,467
Slidell, LA
has anyone bobbed a deuce by simply shorting the frame and bed by 3 feet? i would like to see pictures.
tom
I think I read some threads on different ways that the M35 trucks were bobbed. Some shortened the frame and cargo bed. Some shortened the frame and moved the axle then used a M105 bed. There are different combinations discussed in the threads. I am sure CLINTO or DH will chime in and give you some links to those threads. They are really good at the search feature AND GREAT MODERATORS!:-D
MO MV man
Imperial, MO
That's how I built mine......
And I couldn't be more pleased with it.
I shortened the frame and bed 3 feet.
Shortened the sideboards and troop seats the same (they still work).
Any questions? Don't hesitate to PM or e-mail me.
mckeeranger
Eastern Kentucky
So is the rear axle in the location of the original front axle? (front of the tandem) In other words, were you able to use the stock drive shaft?
MO MV man
Imperial, MO
I centered the axle in the newly-shortened bed.
This ended up moving the axle back 2 inches.
There was PLENTY of splineage in the front driveshaft to accomodate that amount so I went with it.
After MANY miles on the bob, no driveshaft issues to report whatsoever.
