Bobbed Deuce Options
Tinwoodsman
75
Comfort, Texas
I have been thinking of bobbing a deuce and want to use the original wheels and tires. I would also like to keep duals on the rear axle but utilize a deuce front suspension in case I want to go with larger tires later. Finally, I would chop the existing bed. Any issues that would make this project unrealistic?
wreckerman893
Possum Connoisseur
15,626
2,037
I don't have pics on this new puter but if you do a seach of my posts you can prob find a pic of my bobber.....it had 1100x20 tires on it and I kept it dual tires in the rear.
I used a commercial flat bed and fabbed dual exhausts from HUMVEE fording pipes.
If you want a mean look get the 1100x20 raidals and dual them out on the rear.
The NDTs suck on wet roads anyway.
MO MV man
Imperial, MO
That's exactly what I did, initially.
And it worked GREAT!
VERY straightforward project.
Any questions, PM me.
Shortly thereafter, I swapped on the HEMTT wheels and 395 Michelin's.
MUCH better! 8)
MO MV man
Imperial, MO
I didn't have to modify my driveshaft at all.
I only moved the axle back about 2"-to center it in the bed.
And there's PLENTY of splineage in the front driveshaft to accomodate it.
Many miles later and I have zero complaints or problems to report.
militarytrux
Boston Ma
I did the same thing but extended the drive shaft 4" and left a little more room at the front of the bed to the transfer case mount
