JasonS
- 139
- 63
- Eastern SD
I was fortunate to find a steering box this weekend. Wasn't sure if it was going to be a problem having the ports for the assist cylinder but you can see that they are in parallel with the internal cylinder and the steering rebuilder that this shop uses says to just block off the assist ports. 5 turns lock to lock.
Have two saginaw dual piston metric boxes. They have the identical spline shape and count but just slightly too large in ID to work. Do all HF54 have the same size sector shafts?
