mudguppy
- 15
- 0
- duncan, sc
unless that customer is me, then... if its for a customer make sure they pay dearly for it because I think the 8.3 is a huge upgrade for that truck. ...
id be happy with this... TST Power Kit without Video8.3 conversion, hands down, 400/1000 should be very easy to do...
afaik the only difference between it and the civi p7100 is there is no fuel plate in the 8.3, there is a fuel rod that you can adjust instead. The plungers etc are the same. I have a pretty in depth knowledge of the dodge based pumps and by looking at some up close pics posted on gl they are not the same. I have seen those pumps on some of the late 80's early 90's internationals and there is a ton of info on turning those up on the web. And yeah at least put on a poncho for the picsI cannot find a hard answer on the military 8.3 cummins. Does the engine in the M939A2 trucks share the same P7100 IP as the civilian counterparts? Are there any significant differences between the civ and gov 8.3s besides 24v to 24v?
Justin Wehring
979 997 3112
Justin Wehring
979 997 3112
really? how is max rack travel limited? is the 'fuel rod' not the same as the 'arm' on the 5.9's?... there is no fuel plate in the 8.3, there is a fuel rod that you can adjust instead. ...
based on those pictures you posted, i'd say they look the same except for the AFC configuration - looks like the rear-mounted AFC would function the same; boost manipulated diaphram that uses a 'rod' to control rack movement (aka 'arm') versus the 'afc foot' that is directly over the 'arm'. so maybe this is the 'fuel rod' that you referred to?the one on the right is the more common dodge cummins p pump the other is the p pump on the mil 8.3's not to say you could not find one off of a later 8.3 and swap it out.
arm...rod...foot... you knew what I meantreally? how is max rack travel limited? is the 'fuel rod' not the same as the 'arm' on the 5.9's?
give me one and i'm pretty confident i can figure out how to tune it.
good point, i thought about that but didn't mention it. i agree that the TST kit will likely not be of value since the AFC spring is likely different than on the 5.9 pumps.... The reason I wanted to point out the difference is the TST kit mentioned above will not work on the 8.3 pump pictured if this is the same pump in the truck.
I agree with Mudguppy, unless there is a significant financial gain from doing this swap I would try to rat hole it away for a keeper project.good point, i thought about that but didn't mention it. i agree that the TST kit will likely not be of value since the AFC spring is likely different than on the 5.9 pumps.
so there is no fuel plate at all?
to stay on topic - i still vote 'no' to the 8.3 swap unless you are keeping the truck or plan to do more of these swaps in the future. that's too good of a truck to let go.
Sounds like a near perfect combination, I look forward to your input on the conversion, things like does it bolt in? How many hammers did I throw in the field during the process!!Thanks for the info guys. I am better understanding this motor due to your research.
As for the 8.3 in this truck, it is a go. This truck will be sold but I believe that this motor upgrade will serve the end user well. Saving ~1000# and increasing the power by ~60% will wake this truck up as much as removing 4000# of suspension and axle.
With 52" tires it will cruise 65mph at 2000rpm with power and rpms to spare.
Justin Wehring
979 997 3112
Justin Wehring
979 997 3112
Those are my videos and how-to's. As Mudguppy says, it's not going to have an MW pump, so the fuel and timing will be different. It will be as described in the 6BT Cummins section, and also the DT466 from 93-97. The 8.3 turns into a real animal with the fuel plate slid full forward.As Promised at least I hope this link works.
Information found here.
This particular pump is explained under the "international DT466" section with links on timing, fuel etc and a great description of the pump.
