odelljw
- 0
- 0
- Newburgh, NY
What info is available about bobbing a M923a2, I am considering purchasing one, biggest concern is how to remove one of the rear axles... any info about that process? Thanks for any info...
This. Use a steering axle in the back too. That would be sweet.In order to bob the truck you have to remove the complete walking beam suspension and use a set of front springs off a donor truck or fabricate a custom suspension. Air ride is good.
Most people shorten the frame if they are bobbing a regular cargo truck. If you are bobbing a tractor the frame is already shorter.
I have two sets of 5 ton front springs if anyone is interested.
Freightliner FLD 120 or FLD112 rear air bag suspension. I own 2 dump trucks with this suspension setup and they ride a lot different than other trucks with spring suspension. And my 2 dump trucks ride smoother than some pickups.......
Where does one find this... tractor bone yard... cost???the ones i used where also out of a freigthliner tractor, rides very smooth
Did you shorten the frame and bed or leave it stock lengthView attachment 557061View attachment 557062View attachment 557063View attachment 557064
but looks good when you are done ,is almost like the SF 3 ton
