bobtail drive shaft
DUECE-COUPE
Scurry. Tx
bob tailing a deuce and will be installing a m105 trailer bed in it. has any one done this with the original drive shaft and how did it work out for you. I reserched the XM381 and wheel base is 135" this is 5 longer than the wheel base for a deuce from the center of the front tires and the center of the front duals. i have tried to get more out of the drive shaft, but it still will be 2' shorter than needed. please advise.
wreckerman893
Possum Connoisseur
15,618
2,014
That is why I eneded up with a flat bed on my bobber....a former member here (now banned for bad deeds) bobbed mine and did not adjust for the 105 bed.
If you use the stock drive shaft the wheelbase will be just enough off center to look dumb with the 105 bed.
I ended up liking my flatbed better anyway but it is your project.
If you search the forums you should be able to find some pics of my bobber.
