Bolts
rboltz
Hershey, PA
Normally I would try to restore to as perfect to stock as possible. I am taking my 1953 truck apart and many of the rusted and corroded bolts I have found are like in the picture, recessed heads. Are these the original? They are not available anymore so regular hex heads will have to be used.
TGP (IL)
33
Metro East IL
WarrenD
9
CT
Try Bob Stahl at Veteran Vehicles. No net, phone only. I got a bunch of spares from him on my last visit. 508-three-eight-four-769-eight.
A
A/C Cages
Guest
Saturn Surplus in Orlando FL had those last week next to the stainless steel screw bins in isle 2.
There were about 3 or 4 sizes there.
If they dont have them now, wait a week and they might have them again. Thats how they are.
rboltz
Hershey, PA
Totally Stainless (Totally Stainless) has these bolts in stainless, for those who don't want to fight with rusted threads. Not cheap, of course.
Not going stainless. My current thinking is to salvage what I can and the rest will be regular hex head cap screws or bolts. I doubt it makes much difference these days if I use the recessed head bolts or regular bolts as far as "stock" goes.
Oddball-CmK
Thompson, Connecticut
Are you sure? :wink: I have some original take-offs in useable condition... I'll post pictures shortly...
Edit: I have a carton of Misc. M-37 T/O bolts.. included are these type (like the ones pictured).. all look useable with a little cleaning.. but we're all used to that.
/i912.photobucket.com/albums/ac324/Oddball_8/IMG_1724.jpg[/IMG]
If you're interested I'd sell them, as I no longer have an M-37 :(
Mike_L
9
Marion, IN
Nice set of bolts. I've noticed on my 3/8in "indented hex head" bolts (most from my bed), some heads have an S with about 4 concentric circles around it and some have a NL (the L centered on and extending down below the N) with a couple concentric circles around them. They all have the square washer integrated with some washers large and others barely wider than the bolt head. I thought I kept a good record of where what came from but when I reassembled my truck bed, I ran short of some pieces (had to cut a few bolts out) and swapped a few pieces out to make matched sets in certain areas/panels.
Would there be two different bolt manufacturers used in the assy line simultaneously during a run of vehicles? Or, could they have used all S marked bolts and the next month's supply of bolts may be the NL marked bolts? Anyone else notice a mix of bolt markings on their trucks or do they tend to be all the same?
I've had pretty good luck stripping the bolts down (sand blasting, paint stripper, or wire wheel) and painting them. Sand blasting seems to work best with these "indented" bolts with logos. I buy them when I see them at the MV shows if they are in good conditions (20 layers of paint vs. severely rusted/worn).
rboltz
Hershey, PA
I guess mine aren't as bad as they could be. I only have a few that are severly rusted. I was really surprised yesterday when I removed the rear bumpers. I figured those 5/8" NF bolts would be impossible to remove but all came out without much trouble. There was even plating remaining under the paint and under the nuts.
WarrenD
9
CT
There's a lot of metal in these trucks. Many of my bolts that came off got run thru my bench mounted wire wheel and were fine for re-use. I'm taliking body stuff here, driveline is different, new companion flange bolts are a must!
Bill W
44
Brooks,Ga
I stripped my parts truck of as many Dodge bolts as I thought I needed to complete my 37, 13 years later I still have all these left overs
rboltz
Hershey, PA
More on The Findings
As I continue to dissamble the truck, it again surprises me to find the length of many fastners to be odd sizes. Lots of 7/8" long and 1-1/8" and the list goes on. The ones I removed could have been 1/8" longer without any problem and be a standard length. I worked in the fastener industry for nearly 20 years and those lengths, in NF and grade 8, would have been specials and had a premium cost. Of course, when the government does something, cost is no object. I remember government inspectors on-site inspecting the finished products back in the 60's and 70's. If they found anything wrong with a container, and we are talking thousands of bolts, the entire container got tossed. And, they paid for it.
Bill W
44
Brooks,Ga
I noticed that the bolts are in 1/4" lenghs (ie 1 1/4" 1 3/4" ) where as the standard at the stores come in 1/2" lenghs ( 1' 1 1/2" 2")
rboltz
Hershey, PA
Maybe on your trucks, but not on mine. Mine are in 1/8" increments. You measure bolts as "length under the head" and the ones I have measured used my length guage, as used at the boltmaker machine.
You can get bolts in 1/4" increments at many Ace Hardware stores but not always in NF.
WarrenD
9
CT
The bolts you are taking out might not be the correct ones for the application, either. Who knows who took them out and what they replaced it with? Take all the bolts out, toss in pile. maybe the right ones go back where they should, maybe not. Just sayin'
maddawg308
734
Front Royal, VA
Worst case scenario, if you want the old bolt head style, but new bolt (if your old bolt threads are rusted off) cut off the old heads and weld them onto the new bolt shaft.
