Boredom project, LB7 dirtymax turbo on a 6.2
Superhondaz50
66
Fort Mohave, AZ
Just your weekly update. I took some go-pro videos to try and see where my exhaust leak is coming from, 99% sure it's from the #8 cylinder manifold. I can see kinda see the smoke there, see a little spot and oil and it's the one missing the bolt, soooo, it's been there prob the whole time I've had the truck, just never knew as the doghouse was on. So I'm gonna leave it, been good for 4 years, be good another 4 as far as I'm concerned. Opened it up, got it to 9psi, it wailed like a banshee. Got my ceramic insulation, pretty sure it'll give you cancer. My metal order for the doghouse got cancelled so now I gotta go source it locally.
TOBASH
3,488
Brooklyn, NY
Started my doghouse today. Got the frame done and one top panel. Only had one sheet of aluminum so I need to get more.
You need inner and outer shells and inner and outer insulation or else you will suffer burns from the intense heat. You should consider water injection and EGT sensors.
Superhondaz50
66
Fort Mohave, AZ
Figured I'd post some main seal pics while I'm waiting for my doghouse aluminum to show up.it was an old rope seal,prob 1/3 was missing. It slid right out. Replaced with a modem felpro orange seal. Interesting note, the cylinders still have a crosshatch pattern from when the engine was built , cylinders, cranks, chain, pistons all are perfect, this engine is golden good.
rcamacho
839
Bainbridge Island Wa
I need to replace the main seal on my 6.2 998 as well. Looks like you disconnected the starter per the TM but tied it up to avoid the full lift back into position?
Superhondaz50
66
Fort Mohave, AZ
Ya, I just took the two bolts out and pushed it to the side. It's a little tight but much better than removing the whole thing. Don't forget to disconnect your battery!
Superhondaz50
66
Fort Mohave, AZ
Got my doghouse aluminum today so I can finish it this week. Will be great, when it's open and the fan kicks on, it blows heated air into the cab that feels like something from Satan's domain.
Superhondaz50
66
Fort Mohave, AZ
Started the doghouse today. Got the inner siding in and sealed down with high temp metal bonding silicone. I don't want the ceramic fibers getting out. I'll let it dry overnight then sandwich in the ceramic insulation tomorrow.
Superhondaz50
66
Fort Mohave, AZ
Well I got the top and front insulation in and encapsulated, but in the theme of this project I ran out of ceramic insulation. I'll order more Friday when I get my Amazon points (got like $100 coming). For now I tossed the cover on and took it for a spin. It is BY FAR quieter than the stock glass cover, prob by 20 decibels if I had to put a number on it, and that is with it missing it's two insulated sides. I am getting no heat soak through the insulated part of the cover either. Between two layers of reflective aluminum and the super dense ceramic insulation, the heat doesn't stand a chance. Hopefully I'll have this done and painted next week so I can move onto the AC.
TOBASH
3,488
Brooklyn, NY
I went the other route with my Civilian H1... I found Unobtainium. I went with a 9 PSI Whipple. :-D:driver::mrgreen:
If I keep the M1025A1, and in line with your blazing the way after I suggested this route in 2018 and got flamed, I might go with either a supercharger machined to fit OR a military made unit fit in a unique fashion so as to keep the original heads. I already figured out how.
It can be done, so the decision is... "Do I feel lucky"?
Thanks for blazing the way!
Superhondaz50
66
Fort Mohave, AZ
Gotta see pics of that Whipple
