Bought a 5 ton
chris1530
Nor Cal
Hey everyone im new around here..
Just bought a 5 ton 1968, Kaiser with the multi fuel engine. with winch
bought it on GSA auctions
Have a 500 mile trip to go pick it up, been talking with the guy, says its been run quite a bit over the last few years. says there is nothing wrong with it( except broke PTO housing) and it runs drives and stops great.
The pto housing is broke, he says he has another one laying around i can have, to make it work.
Anyway i was looking for soome help, was trying to get to the TM section, and all it does is drop me in classifieds ?
basically looking for the basic info, like what to use in primarys ? where each are located with the multi fuel.. maybe a link to the TM section would help.
THanks guys
chris1530
Nor Cal
Yeah but the Shelter(comand post) dont come with it..
Im just glad a fire department had it, after talking with the guy sounds like they took good care of it, and maintained it.
73m819
320
gainesville, ga.
If the pto housing is cracked, and If you are going to drive it home it will have to be fixed first,
also look at the winch drive sheer pin, good chance the cracked housing was caused be a bolt being used instead ot the correct pin
chris1530
Nor Cal
Yeah im gonna put the one he has on, and refill it with 90 wt. before i drive it anywhere
Ill check the pin to.
wsucougarx
67
Washington State
haha that looks like the 5 ton in Shelton, WA!! Is that the one in the Skok valley? Skokomish River valley that is? If so that truck is about 55 miles from me.
wsucougarx
67
Washington State
Do you plan on driving her home? If you need help I can definately help you out as long as our schedules match. I've gotten "Dead" trucks started and running in the Mason County rural fire dept's (Shelton included). Love seeing the expression of the voluntary fire captains seeing their over a year old deadlined trucks come alive...haha
wsucougarx
67
Washington State
Primary Fuel filter NAPA 3511 (bring plenty for the trip home)
Secondary Fuel Filters NAPA 3512 (need 2)
Need 5 gallons of oil. I use Rotella-T 15/40
Tranny/Transfer case/Differential. I use NAPA GL-1 90w
chris1530
Nor Cal
NIce thanks for offering, and yeah i plan on driving her home..
ive been in contact with the person there over seeing it, His name is Al.
He has told me it Runs and drives fine, Needs battery's, the PTO cover is broken, but he also says he has one of those i can have to go with it.
He told me all I need is Battery's, to change the cover, 90 wt oil to go in the tranny(from craked PTO). Said antifreeze and everything else should be all good to go
But i plan on taking extra stuff just in case
5 gallons 90 wt oil
1-2 gallons antifreeze
brake fluid
15/40 Oil
Tools
Jack
Laptop with DL TM manuals.
Im sure theres more
wsucougarx
67
Washington State
You betcha:
NAPA Premium XL 25-9470 (need 2)-generator/water pump belts
NAPA Premium XL 25-9510 (need 1)- air compressor belt
If you plan on changing out the air compressor belt try and get a hold of the air compressor belt tool. It'll make the job much easier. If not, then bring a big set of channel locks. Also bring a can of PB Blaster to loosen the stubborn bolts.
