Bought a deuce - the journey begins
InTheMitten74
Ira Twp, MI
After a lot of viewing at potentials, I picked up an A2C.
Drove it 175 miles home with no issues except it'll probably need a new rear main seal and clutch over haul while it's open.
She was dripping pretty good when I got it home.
frank8003
4,978
Ft. Lauderdale, Florida
Do not jump to do lots of work
dripping , what is "dripping"?
Drive Her around a bunch and then seek leaks
If She was NOT run long time GI, then She might leak very little after proper use.
WAR machines are built to run run......................................
Just an idea..........................
FloridaAKM
392
Gainesville, Florida
Listen to Frank8003, he knows how these machines react. Sitting kills them, running them makes them shine with proper maintenance.
Welcome to the board & good looking truck. I have one very similar, but without the singles.
NDT
5,916
Camp Wood/LC, TX
Nice truck. Usually dripping is from transmission. If filled to the fill hole it will leak out. Brake cleaner can save the clutch.
montaillou
795
W.WA
Mine always drops a little oil when it's warmed up, but when everything cools down it stops.
pjwest03
35
Vestal/NY
These trucks are in the category of "If there aint't no oil under it, there ain't no oil in it."
Welcome to the insanity! I went for extra long insanity with an M36A2.
gimpyrobb
dumpsterlandingfromorbit!
27,785
747
Cincy Ohio
smell the oil. If its gear oil, you'll know its a trans issue rather than motor issue. Many trans will leak gear oil on long trips.
cattlerepairman
3,127
NORTH (Canada)
When I refilled my tranny after the OD upgrade, I used the specified amount of gear oil and everything was fine.....until the first 2 hour trip at highway speed. The whole right side of the truck was coated in oil. I frantically searched for the leak; this did not at all look ok! I thought the (new) rear main seal had let go. Then I figured out it was gear oil....three cans of brake cleaner later, things were back to normal.
The tranny seems to have its own idea of what the appropriate fill level is. Probably learnt that from the radiator which does the same.
InTheMitten74
Ira Twp, MI
That's exactly what happened once I pulled into the drive at home (after a 3 hour trip on the interstate). Thing made a small puddle in the driveway about 6" in diameter then stopped.
Moving it around yesterday to get it in the barn shown no signs of loss like that.
Did you just spray brake cleaner up in there to clean off the clutch plate?
cattlerepairman
3,127
NORTH (Canada)
Wheels chocked, engine running, sprayed three cans of brake cleaner up into the bell housing and tried not to be lathered by the mess that came back out of the fording hole. No clutch slippage after, so I think I got away with it. That was two years ago.
rustystud
2,389
Woodinville, Washington
The Deuce was just marking it's territory ! Now that you cleaned it up it will have to remark it's spot ! :D
