Bought a M818
NovacaineFix
San Diego, California
Congrats on your purchase, I'm sure you'll be able to get her started, just requires a little TLC and a lot of patience.
Mine was the same way when I got her a few months back, had no batteries and was not sure of the running condition or if it ran at all.
Cleaned the filters, put some new diesel in, a couple of good batteries, some starting fluid and she started coming back to life.
The 8.3 is a good engine, but don't count that 250 Cummins out just yet, they are very good engines. A bit heavy and not that light on the fuel useage, but darn good engines.
Like the others have stated, some of the problems are the fuel lines, fuel selector switch [the one on the floor, not the dash], and that tiny filter that gets clogged on top of the IP.
My emergency fuel valve was stuck also in the off position, which makes starting the engine a bit harder.
Have Fun and keep us posted.
OC455
Floyd NY
What I was told it does turn over but acts like it has no compression. So whether it's true or not I have to find out.
Warthog
224
OKC, OK
Yes the sector valve rebuild is an easy fix. What happens is that the o-rings dry out and allow air into the system.
It is a sticky in the 5-ton forum.
By removing the tool box the job is much easier to do.
red
22
Eagle Mountain/Utah
For a test run pull the fuel feed line from after the fuel filter and run it into a fuel can. Crank the engine over and see if it fires up, a couple sprays of starting fluid is OK while cranking.
This will bypass the common fuel system issues and let you know if the engine is currently working or needs repairs.
NovacaineFix
Take it from me, do not do this:
When trying to get your truck started, do not use the fuel primer pump to pump fuel into the intake, it could cause a diesel runaway situation.
I found this out when trying to get my 818 started before realizing that the emergency fuel shut-off was manually applied even though the handle was pushed in.
Luckily for me, I only pushed the primer in a few times and the runaway only lasted for a few seconds, but man did those seconds seem to last forever.
If you find yourself doing this, make sure the air cleaner cover and filter are off and have a 5 gallon bucket lid handy. It fits perfectly within the open air filter can (the part that is attached to the fender just before the 90° rubber).
The ether method works good and will reduce the risk of a runaway due to the lack of fuel.
As for the compression, you'll probably have to resort to the TM's for what the acceptable range for compression is, as I don't know offhand. As you know, you'll need a diesel compression tester if you can't get it running and really suspect the compression to be an issue.
God Luck man!
Floridianson
2,487
Interlachen Fl.
Do believe you pumped it more than a couple of times. Yes if you got way to much fuel it could run up the rpm and it could also cause a hydro lock. That is why we open the petcock on the intake when bleeding out the air so as not to put unburnt fuel in the intake.
NovacaineFix
Yes I would be guilty of pumping it more than a couple times the 1st round.:-D
But after cranking it a few times with no start [this is before I realized the shut-off was closed] I would have figured the fuel I pumped in there would have cycled through the engine while cranking, I guess it didn't.
Yes a CO2 would do the trick to, but I didn't have one handy, only the yellow powder ABC type and really didn't want to use that.
OC455
Floyd NY
Good thing, we were able to get it to turn over and it fired up. The bendix was kinda froze up, got it working and it turned over. Used the primer a bit and it still wouldn't light up. The kid helping me grabbed a can of starter and gave it a half second blast into the air cleaner and it turned over and fired up. Whoot whoot!!! Let it run for a bit pretty rough idle. The tachometer doesn't work so I can't really tell where it was sitting at idle. It sounded a little on the low end.
So we shut it down and then gave it about 2 minutes and it turned over and started up. Ran it, shut it down gave it about another two minutes and got it started again.
Let it sit for a little while longer and then it would just crank over but not start. So my assumption at this point is it all fuel supply issues. I looked at both tanks and they look like they've been cobbled together. Looks like they may have bypassed one tank completely. So it's probably sucking air all over the place. It does need quite of bit of work, but at least I know the motor works. I'm pretty sure they hacked into the air lines too....bunch of different things going on with that....
Going to break it down and begin cleaning and then draining fluids. Pressure check the radiator...the cooling fins are plugged up near the top. The hand brake is seized in the cab. Again, sme of the gauges don't work, but it looks like the employees using the truck got behind the dash and were messing around inside....the light switch is gone! I have a replacement switch already with LED upgraade lights so no issue there.
Gotta figure out how to get photos from my phone to the computer....ugh. Technology.
OC455
Floyd NY
I think at some point they couldn't get the truck started anymore so they let it sit there because they were getting newer 5 tons (923's) and they also had a couple of M915's there too.
OC455
Floyd NY
Going to be tackling the fuel system with the 5 ton shortly. What fuel line should I use to replace what's there? Going to be replacing the filter and everything. Also going to get the dual tanks working. It appears they hacked into them and made a mess trying to keep it running.
