- 2,811
- 42
- 38
- Mt. Eden, KY
Thanks DH, Cooler is on the list, I have my fingers crossed. A seasoned Cummins tech doubts it. I'll keep ya'll posted.
JC
JC
I meant cylinder liner!Oil and water mixing sounds like the piston skirts.
Myself and another SS member may be up there in a few weeks to load out some trucks for a customer. If you can get some grace time in picking it up we may be able to check it out for you or tow it to your place (we'll have a wrecker with us). PM for details.Gents,
I have a M931 sitting in Indy with coolant in the oil, low mileage and very clean. Engine starts and pressures good. Looking for ideas to fix it. What is the likelyhood of head gasket on the NHC 250, maybe cracked sleeve. I'm 100 miles from the truck and trying to line up a mech to look at it. Ideas?
JC
You can use a pry bar to hold the injector open.Thanks for following up guys! I haven't had a chance to open the engine up yet. First step will be to try and figure out which cylinder(s) we are talking about.. are there any tricks to disable cylinders one by one? Seems like you have to pull the valve covers one by one and see if there's a way to prevent the injector from moving.. can the rocker for the injector be loosened separetely?
