Braden LU2 U-Joint help!
ianfotheringham
Toronto
Hey there team.
I'm busy tearing down a 52 m37, some previous owner decided he wanted a winch and stuck on an LU2 it would seem...not the factory LU4....anyway - i need to get it off before i sand blast - i thought the yoke might slide back enough to get it off the worm gear shaft going into the winch, but it isn't looking likely - thinking i have to remove the u-joint in place (?) - I'm not seeing any snap rings, wondering if anyone has any thoughts - heat? vice press it out in place? there's got to be an 'easier' way......
IsaLandr
Tartaned Goði
186
Centralia, WA
I could be wrong here, but... If my memory serves me accurately, this style of U-joint has C-clip retainers under a lip around the rim of each end cap, right up against the inside face of each loop of the yokes. Look for C-clips buried in all the crap around the inside of each yoke loop. With how much corrosion and crap is built up on this, it's no wonder you can't see them. Assuming I'm right, of course.
Sort of like this, I think:
ianfotheringham
Toronto
Hey, I'm pretty sure you were right on the money, but there is so much built up crud in there, and not much of a way to get at it, I think I'll wait till I rent the sandblaster to do everything next week... That should clean it up nicely....
