slk
- 2
- 3
- Elk River Minnesota
Ok guys I just got through a week of **** trying to get the yoke off of the winch for the PTO. The shear pin was sheared for sure so that was not a wasted effort. I got it all put back together and the winch is doing the same thing as before. It will wind about one turn on the drum and turn loose, and then if you don't put any pressure on the cable it will wind it up. The min you add any tension is slips, and then will start up again. Originally I was pulling a log and it slipped, and I thought the shear pin would solve the problem, but it has not. Any suggestions are welcome. I took the cable off the winch to lighten the load because I am sure I will have to tear into the winch or have someone look at it. Let me know guys what I should look at next..
Thanks
Steve
Thanks
Steve
