brake issue???
onegmjack
Kingsport TN
Just make sure you have good brakes.Always check the fluid before you drive or least do a walk around.My truck had new or rebuilt master cylinder,air pack,hoses,lines and wheel cylinders when I won it in 2009.It is common for mine to leak past the piston cups in the wheel cylinders a small amount but if you x that by 6 would not take much more to empty the master cylinder.So be safe and keep in mind these vehicles are old and need contance attention.For safe operation.
