Brake light trouble.
CaptainHook01
Iowa
I just picked up a 2008 M1097R1 a week ago. I’m new to hmmwv’s I’ve always wanted one and finally have one. When I was checking everything out my brake lights worked. I took it for a short drive around the neighborhood and was told the brake lights weren’t working. Got it home and the brake lights worked. Had someone follow me and they weren’t working again. All other lights work as they should. What could be the problem with the brake lights?
Coug
4,083
Olympia/WA
there is a switch down at the pedal area that is notoriously out of adjustment.
When testing at a stop you tend to use a lot of pressure, but often when running/driving it doesn't take as much pressure, so you aren't actually activating the brake light switch.
There is a way to adjust the switch by loosening the mounting bolts for it, or I did a roadside fix with a couple pairs of pliers and just bent the rod from the pedal to the switch.
Thumper580
209
Virginia
Use a volt ohm meter. Loosen the screws holding the switch.. Set meter to make a beeping noise when the switch is moved(put probe ends in the wires coming out if the switch). Adjust the switch position so that it beeps with the least movement of the brake pedal.......
Mogman
8,289
Papalote, TX
Welcome to the forum!!
CaptainHook01
Iowa
Where is the switch located?
papakb
1,186
San Jose, Ca
I always thought you could add a diode in the circuit so that the E brake light on the dash would light when you stepped on the service brakes as an indicater that the rear lights were working. I never worked it out but it should be a simple addition to the wireing.
CaptainHook01
Iowa
Please let me know if you figure that out. That would be a nice safety.
Mogman
8,289
Papalote, TX
It would take more than a diode, the brake warning light requires a ground to illuminate, there is no ground available in the service brake circuit it simply passes hot along to the rear lamps.
Besides you would NOT want the light to illuminate when you step on the brakes as the brake warning light will also warn you of an imbalance in the braking system when you step on the brakes as it is also connected to the brake equalizer block, the lamp illuminating when you step on the brakes is a BAD thing!
Also it is a parking brake, totally worthless in an emergency.
papakb
1,186
San Jose, Ca
I couldn't agree more with you about reading the -10! New buyers should have to sign off on that before they're allowed to take possession of their truck. As for the brake led, I hadn't considered that it's also a warning for a brake system imbalance but adding another one to the trucks wouldn't be that hard to do,
Mogman
8,289
Papalote, TX
Adding another light would be easy just wire it from the cold side of the switch to ground.
This of course should be the second lamp added, the first and one that everyone with a Detroit engine should have is one wired between one of the glow plugs and ground so one can actually see what the glow plugs are doing, now that could also be connected to the brake switch with a couple diodes for a dual purpose warning light.
