powerram250c
- 0
- 1
- Lockridge, IA
All other lights work the way they should, just not the brake lights. Is the pressure switch for the lights down by the air pack? Thank you!
With the light switch set to power the lights, does connecting the two wires at the switch result in the lights coming on? If not, you may have a wiring issue. You did check the lightbulbs?I have similar problem. Serial, hazards, and turn signals operating normally. Quick fix seemed to be to replace the stoplight switch. Did that yesterday, but no change. Could someone offer some guidance?
Thanks for the guidance - I will check both at next earliest opportunity and report back. Appreciate the help!With the light switch set to power the lights, does connecting the two wires at the switch result in the lights coming on? If not, you may have a wiring issue. You did check the lightbulbs?
