Brake Lines
bigrigoperator
York, PA
I took my m109 out on a memorial cruise with the local classic VW club I belong too.
As I was parking when I got home the brakes went straight to the floor with no application. I did some trouble shooting and found that the hard line that runs to the front axle under the radiator has rusted out and failed.
Does anyone know the size i should replace it with? I plan on getting some stainless line in bulk and replacing all the lines on the truck.
Also i know the line from the master to the air pack uses 1/2in fittings, are the rest of the fittings the same size (also need the thread pitch)?
Thanks all
dmetalmiki
2,027
London England
That shows the necessity of checking under the trucks on a regular basis.
SAFETY WARNING.
Glad that did not happen to you on a freeway...
NY Tom
821
Riverhead, NY
If it's a deuce the lines from the "T" after the air pack to the front and rear are 5/16.The axle lines are 1/4".
Whatever the inverted flare nut size for each of these diameters is that is what you need. I don't remember the thread.
This place Fedhill has everything you need to do the job. I used the cunifer tubing they sell.
jasonjc
283
Gravette Ar.
I like to use the polyarmor from American grease stick , it comes in straight sticks with nut and flares or rolls. You can get it at Oreillys or auto zone.
19,605
Nice diagram!
M37M35
648
East Central Oklahoma
