Brake lining for???
topo
282
farmington NM
checking the part numbers these shoes don't fit m211 truck - m52a2 truck- m200a1 trailer or m269 trailer the numbers should show up and fit some thing ?
Scrounger
69
Southern, Maryland
The FSC (Federal Stock Class) 2530 is for vehicle brake, steering, axle, wheel & tract components. Can you get the measurements of the linings? Need the width and length. And what might help is the size of the drum they fit. If you take a lining and stand it on edge on a large piece of paper, draw a circle using the lining for the pattern. Measure the size of the circle and it will be close to the size of the drum size.
devilman96
17
Boca Raton, FL
Is 2530 a 5 ton?
2530 - Vehicular Brake, Steering, Axle, Wheel & Tract Components
Associated Part Numbers- 580555C91, 594849C91, 2530012702361, 012702361, 01-270-2361
Status Code: 4 - ITEM CANCELLED WITHOUT REPLACEMENT
Replacement NSN: Cancellation Date: 2003, 15, 2
They were made for Rockwell by ABEX CORP FRICTION PRODUCTS AKA COOPER INDUSTRIES but I cant find an end use for them.
3,204
OK, The drum size is 14 to 14.5, Thickness is 3/8 in., Width is 4 in., 14 rivits per shoe. 800 series maybe??
