Brake noise
CanadianAR
Ontario, Canada
Hey guys,
I know I’ve lots of questions recently. Appreciate all the input,
I just finished building my 998 to a desert storm era slant back,
After driving it for about 20 mins I get a clicking in the front. I am a certified diesel tech of 20 years so I start diagnosing immediately.
It sounds like the pads are rattling around. The slightest touch of the brake pedal stops it. And it’s only noticeable on decel maybe below 30mph.
so I examined the front end. Everything seems good, Everything is new. Pads, rotors, caliper mounting brackets, ball joints, tie rods and ends, pitman arm, idler, shocks, bearings were Re locked,
It drives as “good” as ever.
Anyways, the pads move around in the brackets quite a bit, I’d taken this as normal, and I found a website explaining this exact issue and they claim it’s normal and I’m pretty sure it’s my issue.
Axle flanges seem to have a normal mount of play as ay diff with Cv axles,
But it’s annoying as hell, is there any way to fix it?
I’m hesitant to buy new yokes that mount to the diff as it may not improve anything. Even rotating the axle a bit while stationary you can see it pull up the pads then drop them making a click.
Do I just need to put more miles on? Front brakes are under 500 extremely light miles. I mean extremely light truck, going like 25mph. Lol.
CanadianAR
Ontario, Canada
Also looking at the yokes mounted to the diff, they don’t seem grooved or anything to cause this amount of slop. And I foresee trouble getting the bolts out of the aluminum housing. Lol
Everything is OEM from HPG
Mogman
8,572
Papalote, TX
Seems I remember GM having some stick on pads that were applied to the back side of the actual brake pads, basically they were soft enough to imprent the piston so when they were released the pad was indexed to the piston and would not move around.
CanadianAR
Ontario, Canada
I chamfered the edges, but not a lot. Not sure if that could be it too. Any help getting a visual or link on these backers would be great, I am currently searching.
Mogman
8,572
Papalote, TX
I see anti rattle clips for various applications, maybe the pad thing did not turn out to be a good fix.
I would see what civilian applications those pads have and see if there are any clips for it.
